Front air vent window adjustment knob
How do you remove the air vent window adjustment knob. I am actually trying to remove a damaged door and this is my first hang up.
there's a hole in the back side of it that you can thread a stiff wire
or something through to poke out the front cover, which then
allows you to access the screw to remove it.
- Dave
A small allen wrench fits nicely (put the short section in the hole and pry against the door panel at the bend). The only tricky part is finding the hole, but if you feel around with the wrench it will drop into the hole eventually.
Matthew Cervi
'73 tii
