JWadle
Fog Light Switches
2 posts / 570 viewsLast Reply
Can anyone tell me the correct location for fog light switches in my '72 tii (front and rear)? I know one switch is to the right of the radio, but is that front or rear and what is the other switch location? Does either switch light when on? Any part numbers or pics of the OEM switches?
The one switch could power both or you could put the rear switch in the lower dash panel to the right under the steering column. Your choice of what to do of course.
The factory push button does light when on, the button unscrews to change the small bulb.
Some people wire the rear to be the be a 3rd or 4th brake light.
There is a white wire with factory connector next to the battery that will switch the fog/driving lights on/off with the high/low beam switch.
My driving lights are switched on with the high beams when the green fog light switch is on.
