Sign in to follow this
oldskoul
Sounds like tranny slipping, but i dunno
5 posts / 525 viewsLast Reply
74 2002 Automatic
When i take it easy on acceleration no symptoms
When i give it a little punch from a stand still i get what sounds like slipping from 1st to 2nd.
Could this be a linkage problem?
any other ideas?
Recently i had the tranny fluid 'flushed' to see if it would cure problem, it didn't.
....were there any comments from the "flusher" that the old fluid
smelled burnt like an electric motor stink ?
was there very black sediment in the pan and screen ?
if yes to both - then the trans is toast - burnt toast.
time for a rebuild or exchange.
I forget-
can the bands on a BMW box be adjusted? The BW35 could be tightened
up if you caught it early enough, sometimes...
The flusher said fluid looked pretty clean.
He did find a screw in the pan. Which was confusing.
Fluid off the stick doesn't smell burning at all.
Previously the car was garaged for many years.
Daily driving it now.
from your BMW Repair Manual
24-71/3
Automatic Transmission 3 HP - 2
FAULT 1 - Transmission Slipping
CAUSE - a) Accelerator cable disconnected (trans control cable to yur throttle linkage)
B) Oil quantity too low
c) Shift control valve jammed (inside valve body)
REMEDY - a) Attach accelerator cable
B) Correct oil level
c) Exchange control unit (valve body)
FAULT 2 - Transmission shift from 1st gear to 2nd gear slipping
CAUSE - a) Clutches C and C' Slipping
B) Clutch valve and clutch damper C not working
c) Accelerator cable disconnected
d) Oil quantity too low
e) Shift control valve jammed
REMEDY
a) dismantle transmission (new clutch packs)
B) dismantle transmission (rebuild as needed)
c) attach accelerator control cable
d) correct oil level
e) exchange control unit (valve body)
FAULT 3 Transmission Slipping during shift from 2nd to 3rd gear
CAUSE - a) Clutch B slipping
B) excessive axial clearance at rectangular rings for clutch B
c) centering plate bush warped
d) accelerator cable
e) oil quantity too low
f) oil presure too low
g) shift control valve jammed
REMEDY - getting the picture yet ??
FAULT 4 - 3rd gear slipping
CAUSE - a) same sheit as above
bottom line
LOOK at the trans control cable that attaches to the throttle linkage behind the motor and check it's adjustment and a free movement.
If yout throttle linkage is fuched that does not help either for starters
