Stevenc22
Slop in steering components
3 posts / 453 viewsLast Reply
I picked up my first 2002 yesterday and going through it deciding what needs changing. Shaking the front tires you can feel there is looseness in the steering components.
I have traced it to the connection between the relay rod and the steering drop arm / pitman arm.
See picture.
There appears to be a bushing between the 2 components, do we think it is a simple and replacing this bushing or is there a lining in the hole on the steering drop arm that could have worn away? Maybe I need to replace the entire relay rod?
Thanks
Steven
also, did you check the screw atop the steering box? If it's above the locking nut, that has room to tighten slop if the box itself is causing play. There's a proper way to adust it, if you do. (both front wheels off the ground, I believe)
I don't know about the bushings, sorry.
Scott
That track rod's the first weak link- they don't last more than 8 or 10 years...
heh
Yeah, just change the rod- it's kind of a pain. If I didn't have someplace
to work on cars, that would be a job I'd pay someone else to do!
