Guest Anonymous Posted July 6, 2003 Share Posted July 6, 2003 Would it be safe to say that if I had a shortened 02 platform and a long 02 platform, measured the difference and cut that value out of a new 02 linkage rod that I would have a correctly shortened shift linkgage rod? I'm plan to use the 02 shift platform that I had installed with the 5 speed conversion/m10-- this will be used with my 323i 5speed/m20 combo and move the shift hole aft as necessary. Right now I have a shortened linkage rod that was incorrectly shortened (B.A.) but the old one was never measured and tossed. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 6, 2003 Share Posted July 6, 2003 I went by the 3.56 inch(I think) measurement that a lot of folks use. I shortened the platform and linkage by the sme amount. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 6, 2003 Share Posted July 6, 2003 Bill, in addtion to what I emailed you...the way I did it was measure it all up,preparing to shorten the arm the same amount I shortened my driveshaft...BUT...I also got in the car, held the shift lever up at the angle to which I wanted it..and THEN cut it to fit. Common sense prevails in this operation.. Matt '72 02/m20 Quote Link to comment Share on other sites More sharing options...
