Brake fluid hose
5 posts / 509 viewsLast Reply
Is there a secret to getting the blue brake fluid hoses onto the nipples on the reservoir and brake booster? I can't get them on more than a fraction of an inch.
Thanks!
Fran Ferrance
[email protected]
1972 2002
Brake system grease!
The kind you use when rebuilding calipers. NOT the kind you put on the bolts
on the outside.
It's hard to find- Pegaus carries it, and Autosport Seattle usually had it.
www.pegasusautoracing.com
Assembly lube works, too, but not nearly as well.
All of the above works and I sometimes put a pair of needle nose pliers in the hole and stretch the hose just a bit.
put a little silicone grease on the end of a tapered punch, slide it into the hose end about 1--15mm, and let it sit that way for a few minutes. Then warm it up with a little hairdryer heat and quickly slip it onto the plastic nipple.
More difficult-getting the nipple into its rubber grommet on the M/C.
cheers and happy stretching
