Need jet sizes for Weber 45 DCOE's....
I searched the archives and couldn't find it. The motor is 2.1L, has a 304 degree cam and 11.0:1 compression. Any help will be appreciated.
Thanks,
Leif
'76 '02
'75 '02
38mm choke
155 main
f9/f16/f2 emulsion tube
190 air
55f9 idle
40 pump
4.5 aux venturi
or just call ireland and ask for their recomendation. No one knows for sure so you must make about 3 guesses to get it close.. oh btw.. this is setup is tuned for full out power and not flexibility (sissy road driving) asuming your cam makes max power (torque) at 6250 rpm.. and should redline around 7200 or so. if you put in stock valve springs I'm going to hit you... hard.. very hard.. party on
Kris
I didn't... at a solo2 two days ago I sucked one a nylock nut holding on a short air horn into the #1 chamber... made a nice mess out of the surface of the piston and the bottom of the combustion chamber...!!!
