Any advice?
I've just spotted an oil leak from the exhaust manifold stud on my E12 head (#2 cylinder, top). I'm afraid to look. Could this be something other than a cracked head?
some of the exhaust manifold studs bolt into open oil passages - i do not recall precisely if the top #2 does or not - take it out and put a decent sealant on the threads and reinstall (i have always used a generic SealsALL with good luck) - hopefully this will cure the leak
bob
valve train area....when all the valve train is taken out....you can see right through....
Just put a good sealant in there and you'll be all set...also make sure that the studs have enough thread in the head inself....some of them have a "threadless: area along the length of the stud......I think its the shorter threaded length that gets put into the head, and the longer length goes into the manifold...
Hope this helps
02MonsterMike
