Sign in to follow this
ClayW
1974 2002tii in Richmond, VA $12500
6 posts / 1130 viewsLast Reply
NM/NA
Anyone know this car?
http://washingtondc.craigslist.org/nva/cto/3214608358.html
1974 2002tii for sale:
Total babe magnet, head turner, blast to drive car.
I am the second owner in the past 20 years. The previous owner was a total 2002 nut. He was meticulous with rebuilding this car, and more importantly, he had the money ship the car to Korman to do it right.
Korman Autowerks did a bare metal restoration on this car in 1999/2000. I have $20k+ in receipts and documents from that restoration. Since then, all maintenance has been done at Sportscar Workshops in Richmond, Virginia.
Originally Amazon Green, repainted British Racing Green - it's actually pretty close to the original color.
Less than 15k miles put on the car since the Korman restoration. Odometer stopped working at 85k a couple of years ago. Considering that everything has been rebuilt, I never cared at all to fix the odometer. I drive the car twice a week - about 5 miles each day.
Drives great. No bumps, no squeaks, no rattles. Pulls hard. Needs nothing to be daily driven. I wouldn't and don't hesitate to drive it anywhere. With the 5 speed transmission, this car hums down the highway just fine. With the Korman road/sport suspension package and the beefy swaybars, there is barely any body roll. It really is a drivers car - organic and analog. Working sunroof!
Korman did a complete engine rebuild, all new suspension, 5 speed transmission, new paint, new moldings all around, new carpet, reupholstered seats. It needed a little refreshing so the car was resprayed in 2009 with what I call a "sympathetic" paint job. It's not perfect - has a couple of cracks here and there. It passes the 5 foot test and is still a total head turner. No dings, no dents. Strut towers look great. There is a small amout of surface rust in the spare tire well. Never bothered me, but the new owner might want to hit it with a steel brush and a respray.
I bought the car the day that it was listed for sale about 6 months ago and have loved driving it. I actually got into a bidding war with someone else who was also trying to buy it that day. I'm only selling to pursue a new business venture.
The car is located in Richmond, Virginia.
I plan on posting a sign on it at Cars & Coffee next weekend.
$12,500 OBO
Here are the main bullet points:
Korman Stage 1 Engine:
160 horsepower build with new:
9.5:1 Mahle pistons
Connecting rods
Rod bearings
Rocker arms
Rocker shafts
Crank shaft pilot bearing
Valve guides
Oil Pump
Water pump
Slide rails
Replaced all Gaskets/seals
Timing chain
Dyno tuning
Port matched all cylinder head openings
Swirl polished valves
5 angle valve job
Mechanical advance distributor
Bosch sport ignition coil
K&N filter
Stahl ceramic coater header
Performance exhaust (sounds great! loud enough to be exhilarating but not obnoxious)
Korman Road/Sport Suspension Package:
Rebuilt front and rear suspension
Urethane bushings
Sport springs
Bilstein HD front shocks
Bilstein HD rear shocks
22mm front sway bar
19mm rear sway bar
Peened and plated hardware
Powdercoated all suspension components
Brakes and Other Stuff:
Rebuilt steering linkage
Rebuilt axle halfshafts, peened and painted all parts
Replaced all wheel bearings
Replaced all brake lines with steel braided lines
All brake hoses and tubing replaced
Front big brake conversion
Ventilated rotors
Larger calipers
New brake pads
Rear big brake conversion
Short shift kit
Quick ratio steering gear box
Rebuilt rear differential
Interior and Extra Parts:
New carpet
New mats
New trunk mat
5 genuine Panasport wheels with 185/60R14 tires
New chrome trim and moldings
Hella driving lamps (pics don't show the covers - have new Hella covers for the lights)
New windshield
All new rubber gaskets and window moldings
Burlwood shifter
Jackie Stewart race wheel
Powdercoated front and rear strut towers
Undercoated entire under chassis
Year 2009
Custom drive shaft from Sportscar Workshops
Rebuilt 5 speed shift linkage
New tires
New BRG respray
Rebuilt starter
New electronic ignition
Year 2012:
New voltage regulator
New alternator
New hazard switch
That sums up most of it. I have documentation and receipts from Korman Autoworks for all work done. Since 1999/2000, it's really just been oil changes and the last couple sets of bullets points that you see.
After combing through the details - if you're prepared to spend $12,500 on a really, really well sorted 2002tii - email me. Will come with 2 car covers.
I'd really like to see the car go to an enthusiast.
Don't know the car, but if anyone needs a local to check it out, I'm your guy. The pics were taken in front of Virginia House, Windsor Farms, a high rent neighborhood.
Hey MartyR, you still looking? This one looks like a driver.
Cheers,
MFB, in Richmond, VA
73 tii in pieces in the garage.
NM/NA
It's mine :)
Lots of interest but I still have it and it's still for sale.
I keep it stored at a buddy's shop but I'm picking it up tomorrow for the weekend.
804-three-three-nine-1001
Darren
Cheers,
Too rich and big-bumpered for my blood. Nice ride nonetheless!
