Guest Anonymous Posted July 2, 2003 Share Posted July 2, 2003 URL: http://www.zeebuck.com/02bc/index.htm I know that people say the 2 mufflers won't interchange, but why not? I have a 75 with NO muffler, and a PERFECT, Eberspacher side exit muffler in the garage. Is it just a case of mounting points, and rear valence, or will it not fit at all? Al Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 2, 2003 Share Posted July 2, 2003 match up the mounting points between the center and side exit mufflers; even if they're not the same you can always scrounge a mounting bracket from a parts car (you did save the one off your parts car, didn't you ;-) and bolt, weld or pop rivet it in the proper location. If you check your lower valence panel, you'll see the stamped but not cut location for the side exit pipe; cut it away with snips or an air nibbler and you should be in business. It's not like you're trying to keep the black car absolutely stock and original... Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 2, 2003 Share Posted July 2, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 3, 2003 Share Posted July 3, 2003 URL: http://www.zeebuck.com/02bc/index.htm (nt) Quote Link to comment Share on other sites More sharing options...
