Getrag Transmission Gear Ratios- 240 a bad transmission??
I found this on the Bimmer Forum. Spent about 30min looking here. Couldn't find it.
Now I need to know why the 240 is not a good transmission, any help?
Getrag Transmissions.
The 1977-79 E21 320i uses the Getrag 242 (4-speed).
The 1980-82 320i(s) uses the Getrag 245 (5-speed).
The 1983 E21 320i(s) uses the same Getrag 240 (5-speed) as the 1984 E30 318i(s).
4-speed - 320i - Getrag 242
Gear ratios
1st - 3.764
2nd - 2.02
3rd - 1.32
4th - 1.00
5-speed - 320i - Getrag 245/4 Overdrive transmission ’80 – ‘82
Gear ratios
1st - 3.764
2nd - 2.00
3rd - 1.33
4th - 1.00
5th - 0.81
5-speed - 320i - Getrag 245/10 close ratio/”dogleg”
Gear ratios
1st - 3.764
2nd - 2.325
3rd - 1.612
4th - 1.229
5th - 1.000
5-speed - 320i - Getrag 240
Gear ratios - almost the same as a 245/4
Transmission Weights:
Getrag 242 - 48 lbs
Getrag 245 - 63 lbs
Getrag 240 - 62 lbs
Both input shaft diameter for the pilot bearing .471”/11.9634mm
The Getrag 240 transmission came with aluminum shift forks, which were not as durable as the steel forks in the 245. Aparently this caused some 240 failures. If I recall there are some members here with 240 transmissions in thier racecars, as they are lighter and shorter than the 245.
I have a 240 from a '83 320i that I will be installing soon. Others have installed 240 transmissions as well so Im sure they will chime in.
Edit: If you get a 240 get one from a 320i. The E30 240's have 2 mounting tabs and do not have the speedometer cable hookup.
Thanks MAD02 I really appreciate it. I like the lighter and shorter idea. I had great luck with a T10 on a raging small block even though all the old timers said it wouldn't work.
I think it has more to do with the left foot than the strength of the transmission.
  • 5 years later...
Did you install the 240 and so you have a guide or Photos?
