Guest Anonymous Posted June 26, 2003 Share Posted June 26, 2003 replacing the rear main seal and got the clutch and flywheel off. while i got them off i want to clean them before reassembly. what's the best stuff to use? i'm thinking of using brake cleaner or carb cleaner? thoughts? thanks tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 26, 2003 Share Posted June 26, 2003 you might want to get your flywheel resurfaced since its already off. its only $20 or so. and unless your clutch is pretty new, have you considered replacing it since you have everything apart? and carb cleaner would probably be fine to clean the metal bits. just don't get it on the friction surfaces. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 26, 2003 Share Posted June 26, 2003 URL: http://www.zeebuck.com/02bc/index.htm Brake clean will be fine on friction surfaces, but you may want to replace the clutch while you're in there. If any more than a few drops of oil gets on the disc, it will have soaked in, and no amount of cleaning will remove it. It will seep out in the future, and cause a slipping clutch. If not much oil got on the disc, then brake clean, and some fine sandpaper/emory cloth will clean it up OK. Al Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 26, 2003 Share Posted June 26, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
