A COMPLETE Guide to Megasquirt on the 2002
ahhh! my afr's taper down to 12.4 at WOT/7500 rpm from both axis of the tp vs. rpm matrix. theoretically max tq is in the low 12's, hp around 12.5 iirc. the middle of my matrix looks like yours. i run 15.1 in the "highway cruise" TP/rpm range for econ.
i am sure anyone going MS appreciates the time you took to post all this setup data!
2xM3
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thanks for the info. I will try bringing it down to 12.4 and with a steeper taper. =)
  • 7 months later...
  • 1 month later...
  • 2 months later...
SUPER POST!!!  Any changes?  I am getting ready to build and I have this exact set up!  Thanks for the EXCELLENT post!  This helps A LOT!
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
SWEET!!!!  That is from heaven!
Thanks, but I still have to work through a few issues.  I think I've got most of it sussed out at this point, but I have to put things temporarily on hold as I may be switching jobs!
  • 10 months later...
I prefer fuel cut for the limiter and I set it hard at 6500.
Hi Colin, have you tested this out?  I still want to program in a rev limit on my MS but have been too scared to test it out! :P  Also, do you have any hunting/surging problems at idle from the timing dip?  I did and so now I'm flat across at 18 deg.  Just curious, thanks!
-Carl
-Carl
I test the rev limiter daily, provided my commute allows for it.  :P
No hunting or surging at idle at all.
  • 7 months later...
What a great thread! BRAVO! Just curious for the folks who are considering going with a turbo, would most of the settings be the same? Obviously with different rate injectors, that would need to be changed, but I would hope that most of the other work to set it up and get it running at least would be the same... one can hope...
Simon
Daily: 2017 BMW i3 REx ' the commuter'
Weekend: 1975 Alfa Romeo Giulia Nuova Super 1300 ' the polluter'
