Fitting engine in car - m20
M20 guys-
There is a tab sticking off of the left side of the transmission bellhousing. It has a hole in it, it looks like it might be for a mount or something. This tab doesn't quite clear the firewall when I put the engine and tranny in the car... did you grind it off, or just hammer a huge hole in the firewall for it? I'm thinking I will just grind it off, because it doesn't look important.
One step closer...
Ben
Oh yeah - My engine is too far forward by about 1" or so, and too high by about a half inch. If I can get it to slide back just a little bit I can get all the mounts on, and life will be good... but it won't go back because of that tab on the transmission.
Is this an indication that either the engine is sitting skewed, or that the body of my car is off? (It has been in its share of wrecks).
I'll try to post some pics. Thanks.
