Aussie built for drifting.
  • Replies 48
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
do you have more pics of the rear, where and how you mounted the nissan rear subframe
Here is the rear cross rail for the subframe. The round bar is welded top & bottom in the RHS like a crush tube, and the round also has a 3.2mm wall thickness because it also is needed to act as a locator for the 2 rear mounting bushes in the subframe.
SR2002 Project
O==00==O
The end result once done is all Nissan
Adjustable control arm kit.
R33 Skyline 5 Stud hubs
R33 Skyline Brake discs and calipers
R32 Skyline LSD diff and drive shafts
Last picture is the nissan strut top mounting plates grafted in to replace the BMW shock tops.
SR2002 Project
O==00==O
  • 2 months later...
Well it's been a while since i last up dated.
Since last post i had been hunting down a power plant. Most suppliers wanted $3,500 (or more) for a front half-cut, or wreckers wanted $2,500 just for a motor and loom with ecu but no gearbox.
So I started looking into damaged vehicle motor auctions. Silvia's, 180SX's, 200SX's from S13 to S15 were selling for between $3500 up to $5000 depending on there condition. At least this option gave me a complete car to use whatever else i needed to complete the build.
I finally acquired a '96 model S14 VCT SR20DET 200SX with hail damaged repairable write off.
In all, it's a good buy for $2,600. Ran on the dyno at 14psi pulled 248 rwhp (185kw).
At this stage now fabrication is done, all but the g/box mounting points.
All the Nissan front bulkhead is finished, which has allowed the use of the nissan pedal boxes, plus the height adjustable steering column. Another big bonus doing this has allowed for the brake booster to be mounted on the right hand side, unlike the original '02 dual boosters that were on the LH side (which would have been in the way of the turbo).
I decided to go with a Painless wiring loom for the car, to avoid any potential future issues with the old loom. When I removed the OEM loom I noticed it was badly weathered and brittle. I will be also using the Nissan engine loom and ECU for the short term.
A good friend has started to make the carbon bonnet and bootlid. Plus I have been lucky enough to get the loan of a turbo front spoiler mould off another '02 FAQ user "devilspace". And I am still undecided about going with a full Zender Alpine style wide body kit in Carbon or the go with the Tii turbo bubble flares.
Inset to fit the Nissan booster
2012-10-22_12-49-14_5602012-10-22_12-19-36_525
Fits like a glove now. Once completed, the pedals boxes (Right) all bolt up like factory.
2012-10-21_11-41-54_7812012-09-24_16-39-29_414
Rolling chassis again is a good feeling (Left) Taken just after the Roll cage was finished (Right)
2012-09-24_16-32-27_6282012-09-24_16-38-40_111
SR2002 Project
O==00==O
The Donor car, Australian Released Nissan S14 S1 200sx. (249 RWHP @ 14psi)
Took it out to Wakefield Park raceway to see if there were any potential issues that need to be fixed before transplanting into the '02. Luckily, it didn't miss a beat.
Edited by staunch2002
SR2002 Project
O==00==O
  • 1 month later...
More updates after a long break during the festive, i have finally regained some motivation.
New centre console
2012-10-17_20-42-33_9152012-10-23_14-04-47_103
2012-10-24_19-15-05_8532012-11-08_15-28-03_804
2012-11-08_15-28-43_442
1st attempt for making custom 2002 badge, went horribly wrong. As someone else mentioned... looks more like a Ferrari badge!!!
2013-01-03_00-49-23_680
Have finished chopping into the rear qtrs to fit the temporary flares. Will also be ready for wide body kit, once i decide which style i prefer.
2013-01-08_22-49-50_851
2013-01-10_18-08-20_991
Boot lid lock pin plates.
2013-01-15_18-01-16_117
2013-01-22_01-01-08_87
Still a long way from being ready for paint. But did a test for the preferred Satin Black look, and thinking it will be the right choice.
2013-01-22_01-06-54_217
Not being a panel beater, this has been the most ambitious decision i have made to date... fill in the rear bar groove, plus change exhaust cut out to the centre.
I just don't like the look of the rear without the bar, and hope that this decision to fill it in, won't haunt me for ever. So far, i'm happy with the outcome... time will tell... Dare I ask for anyones feedback???
2013-01-30_21-29-47_71
2013-01-30_21-30-21_184
2013-01-30_23-50-23_224
SR2002 Project
O==00==O
Hey,
Im about to start a very similar build i have a 1990 240sx with an sr20det set up in it,also i have a 1971 2002 i bought to do this project 4 years ago and every person i talked to about doing it and getting some help from either told me not posable or it is not worth it. so i let the car sit didn't want to sell her. saw your build and now i am starting the project over again. i was wondering if you ran into any major problems or if their was any issues you could help me past. Any help is highly appreciated.
Thanks
Hey,
Thanks
Are you intending to just put the SR into your '02, or complete suspension and driveline? Is your intention to drive on the streets registered, or for track only use? Our cars here in Oz, are RHD, which will cause a new set of issues that i haven't had to deal with.
Happy to help if possible, which ever direction you are thinking of.
"It is not worth it." Time will tell for me, but it has been worth it so far. I am yet to drive it though, it could be an epic fail. I have undertaken this build just to have something unique. People may argue that its unique..ness, is BAD or GOOD. Either way i will persist and tweak until i am happy with it.
SR2002 Project
O==00==O
