Guest Anonymous Posted June 12, 2003 Share Posted June 12, 2003 URL: http://www.zeebuck.com/02bc/index.htm I think I'm now paying for all the fun I had on the Sea to Sky highway last monday. I knew it was too good to be true, and the 02 was too perfect lately. Anyway, I finally got the bolts undone on the back end of the driveshaft, so I was feeling pretty good. Next thing I did was grab my GOOD driveshaft from the garage rafters, and put it on the bench. What did I find? The rear U joint is notchy as hell!!! Its actually worse than the one I just removed. I KNOW that I checked that shaft when I removed it from the parts car, and I'm positive it was good. Oh well. I guess I was wrong. So I called the local driveshaft guys, and they quoted me $215 for the rear joint, or $330 for both. I'd like to do them both, but hell, right now, I can't even afford one! Al Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 12, 2003 Share Posted June 12, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 13, 2003 Share Posted June 13, 2003 I drove on a notchy (not loose) u-joint for five years without any problems. I was on a 5spd conversion and the driveshaft shop said they needed new joints, for $350! I said no thank you and put it on my car. No problems. But wadda I know, I'm just a cheap bastard with some things. 8-) Dan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 13, 2003 Share Posted June 13, 2003 URL: http://www.zeebuck.com/02bc/index.htm Its not that I'm cheap, but it has more to do with being poor! I'm now considering "maybe" using the notchy one for the time being. Zenon has a good rear section, but it needs a centre bearing, a front section, and a balance. Total cost will be $128, with new bearing, and balance. He's even delivering it to my house tonight. I'll have to consider my options closely. Thanx. Al Quote Link to comment Share on other sites More sharing options...
