Guest Anonymous Posted June 11, 2003 Share Posted June 11, 2003 I have the one in my owners manual but the pages are stuck together and riped a little. I cant see the top left part that has the info about the spark side of things. Also, I've found some online but they all seem to be for earlier years. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 11, 2003 Share Posted June 11, 2003 bolts to the engine block infront of the starter, but where does the smaller part go? It looks the perfect length to attach to the outside of the alt but I doubt the alt needs to be directly grounded like that. Any other ideas? Otherwise I'm just gona chop it off and try to make the stock wiring diagram work. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 12, 2003 Share Posted June 12, 2003 ...typically, to the side of the battery tray. Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 12, 2003 Share Posted June 12, 2003 The smaller leg of the negative battery cable should be connected to the body. There should be a screw hole on the side of the battery tray as Chris said. Don't chop it off, or you'll have problems with your temp and fuel gauges. Curt Quote Link to comment Share on other sites More sharing options...
