Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 URL: http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11251&catalogId=11005&itemId=63216&catGroupId=11085&modelNo=CQ-DP383U&surfModel=CQ-DP383U I'm putting in a DIN sized receiver/CD, replacing the old shaft-style radio/cassette. In the Clardy console, the radio is at the bottom, allowing the back of the radio to lay on the hump under the AC stuff. So all I need to do it get the front cut and properly install the DIN sleeve. Utility knife? Dremel-type tool? Would it melt the thin plastic? Other? I went with the one in the link because it plays MP3, has a black face and a nice, basic display instead of the gaudy multi-color things on a lot of them. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 Altho it was an aluminum faceplate that I cut. I've done plastic faceplates in the past and they are much easier. I used a small diameter drill and made a perimeter line of holes around the outside, then just used a flat file to finish it off. The stereo bezel should cover up any uneven areas, altho with a flat file you should be able to get very close to straight. The CD-type stereo bezels don't cover much tho!! 8-) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 My Behr console had a DIN sized line embossed around the stereo hole that I simply traced over a few times with a sharp utility knife. I also seem to remember having cut perpendicular to the line traced by the utility knife in a few places with a hack saw to enable me to wiggle pieces of the console loose in the same way you'd wiggle a loose tooth free. By utility knife, I mean one of those traditionally grey metal units that holds trapezoidal blades. Quote Link to comment Share on other sites More sharing options...
