Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 I have a 1970 2002 trying to do it with an s14 M3 engine but i have not found the right one. Need some info, whats your suggestion. thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 For the price of the engine alone (before any needed engine parts, machine work, and ancilliary components) you can do a full m20b25 conversion. Many s14's have seen a lot of use (read abuse) and may need some extensive work. How do I know about pricing? I'm doing one. I have what I consider to be 90% of the parts assembled and I havn't even come close to the cost of a used s14 CORE without harness, ecu... The power is sufficient to satisfy even the hungriest of addicts. (rode in one last week) Good luck Bill Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 if it is a 525i. The only years that had the m20 are 81-90. Only 88-90 had the 170hp version. The others are 150 I think. 525e had 125hp. You will need a transmission... this you should consider your most critical path. Bill Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 Ball park? Big bumpers scream for a six. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 my inital estimate with buffer for unforseen problems $1700.00 Quote Link to comment Share on other sites More sharing options...
