Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 Negative cable to rear shock, positive up front to starter, anything else? I'm not exactly taking the route from the FAQ home page with the distribution block, etc. Will this work? Byron 76 02 inka Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 Shock is mounted with rubbers so you don't get a connection. Ground connections are very important, they should be as good as possible, both from battery to body and from body to engine block. Tommy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 of the car. Best is if you make one yourself. Sand all the paint off of an area the size of your washer, then sandwich the end of the cable eye between two washers using the bolt/nut after you have it all done, it should be: Nut, washer, bare body metal, washer, cable eye, whasher, bolt head. When you get it done like that, cover it in a light coating of wheel bearing grease and it'll never corrode etc. (maybe overkill, but wth) Best of luck w/it! B Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
