s14 front pulley hits fan!
I had the same problem when I put a 320 pulley on my car. To fix it I put 4 thick washers behind the fan. I don't know how much you need to move yours forward so I don't know if this will work.
Good Luck,
Leif
I had the same problem when using a 320 engine with the
longer pulley that accomidated the a/c belt. I just eliminated
the engine fan and wired up a 320 electric fan in front of the
radiator instead. I've seen lots of 2002 owners go to the
electric fan for various reasons, and it works well. you just
have to rig up a coolant temp switch to trigger the fan, search
the archives for auxilary fan and you should be good to go.
- Dave
Did you use your old engine mounts? If they're a bit
knackered they'll allow the engine too much movement -
does it only happen under braking, or is it constant?
The other UK RHD M2 experienced this and has just ordered
the Ireland Engineering urathane mounts to stop any engine
movement (which they do, brilliantly)
HTH, Nick
...as I was discussing this issue with another M2 owner just
the other day.
In that case go with the other suggestion and use an
electronic fan mounted infront of the radiator - real easy clips
now attach it direct to the radiator and it's a piece of cake to
do.
