Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 It not have to use vacumm lines. I dont have any vacumm lines (002 tii dist.) In the past and present, I am using those cheap little rubber vaccum caps u get at parts stores. The problem I am having is that they keep cracking (heat and age). What have u guys/girls done to prevent vaccum leaks? I was thinking JB Weld? Lyle Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 fabricator heliarc everything closed. Filed and sanded all the welds smooth, then bead blasted the manifold - looks very slick. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 10, 2003 Share Posted June 10, 2003 I unscrewed my smog ports from the manifold and cleaned up the threaded areas and welded em up using my 135 mig and it went like butter. Then used a 4.5" grinder to dress things off smooth. Also welded up the holes inside the exhaust manifold that held the "injection straws" or whateverthehell . Added new studs to the down pipe flange and hogged out the manifold to gasket match it about a inch deep. Nice and easy like. Quote Link to comment Share on other sites More sharing options...
