Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 This time on the drivers side of the main engine block, towards the back. Kinda below the dizzy, where the drivers side heater hose comes through the fire wall... A 3/4 inch long or so tube comes out of the engine block, maybe 1/8th inch in diameter or so. Obviously made to have a hose put on it. What is it and what do I need to do? I'll post pics if needed. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 If it's the fitting I'm thinking of, it's for the return of coolant passed through the stock intake manifold. If you're running a downdraft on the stock manifold, I'd suggest using it. For sidedrafts or fuel injection, block it up with a plug. Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 heated choke. The one that takes coolant from the manifold to the heater box is about 1" od / 3/4" id Quote Link to comment Share on other sites More sharing options...
