Guest Anonymous Posted June 7, 2003 Share Posted June 7, 2003 the guys (stevek?) who are running a lynx and single weber45dcoe, what are you doing with the vacuum advance? are you just not running it? is there a suitable port on the carby for it?? someone must have the answer cheers ozgeorge Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 7, 2003 Share Posted June 7, 2003 The DCOEs have a port on each barrel, just below the throttle plate, next to the idle mixture screw. You would need a threaded adaptor for the port. I believe these are most commonly used with a vacuum synchronizer, but it seems to me that one of these ports might work for your vacuum advance... seems to be in the correct location. See pic below for location. Anyone else have any comments on or experience with using this port? Cheers. Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 8, 2003 Share Posted June 8, 2003 thanks chrisb Quote Link to comment Share on other sites More sharing options...
