Looks like the sagging was from the front not back...
When I got this car, a 76 2002A ..it always had a sagging look in the rear, from the front it looked fine. I swapped the rear springs with my tii ones, switched them, the spring pads looked fine etc..but the same sagging persisted. So I got one of those strut spacers, I put it under the front driver side strut. So only one strut has the spacer. Should I replace the spring or can I run it this way? This wheel has more neg camber then the pass side. Looking from the front is noticable. I fear the worst in that the subframe is tweaked or a bent strut. When I replaced the strut cartridge 2 weeks earlier, it didn't want to go in all the way it seems but it wasn't too hard too screw on the cap. Never thought much about it at the time.
the car is sitting evenly..at least that's what my eyes saw. Still a bit higher rear end, still have to work on that one.
