Another sunroof Q
and I don't think it would be easy. You'd have to weld some fittings from the underside of the 320 sunroof panel itself to the '02 panel and make up new brackets to support the crank mechanism (they're different). Cables are also different and would have to be made to fit the '02 opening. The only way to really tell would be to delve into a derelict 320, rip out the headliner and observe all the pieces in place, then do the same for an 02. It might be easier just to swap out the center of a 320 or E30 roof with same on a non-sunroof '02. A lotta trouble for a little ventilation--but a challenge!
Mike
