Guest Anonymous Posted June 6, 2003 Share Posted June 6, 2003 My headlights keep blowing. I checked the voltage at the headlights and I'm getting 16 plus volts at the headlight plugs. Any ideas what the problem is ? Thanks for any info. Forgot to say this a 74 tii. Chris Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 6, 2003 Share Posted June 6, 2003 If you have 16V somewhere, either the battery in your tester in empty, or the voltage regulator (little metal box on the left-front inner wing near the alternator) is broken. If there's a modern regulator, you could probably pry it open bij removing the tape around the base, you should find a trim-resistor to adjust the outgoing voltage. If you have an old one (or a modern one that is broken), get a new one. Good luck, Hugo Quote Link to comment Share on other sites More sharing options...
