Ok, someone tell me what I put in this hole...
Its the thing in the black circle. It has 2 nipples on it, one is connected to a tube that runs to the brake fluid resevior, the other nipple is in question. It comes off the front of this part. It's located under the brake/clutch stuff, kinda down off the side of the lower block. I assume it has something to do with the brake system but this car was in such a mess when I got it that nothing is for sure.
What should I hook it to?
Follow me: From the side of the brake fluid res mounted on the fender, there is a pipe that runs down to the clutch master cyl. From the master cyl there should be either a flexible line with metal ends or a plastic pipe connected to the clutch slave cyl. This is mounted on the side of the transmission. The slavecyl is usually the only one with a bleeder nipple on it.
Thanks. its def the slave, because from the brake res the line first goes to the master, i didnt notice that before. then the line goes to the slave. so what does that nipple hook to? anything, or is it just for bleeding the system?
