Guest Anonymous Posted June 4, 2003 Share Posted June 4, 2003 Does anyone with a S14 Crank in an M10 block get nervous by how close the crank's counterweights get to the oil pump support bolts in bearing cap #3? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 4, 2003 Share Posted June 4, 2003 thousands while turning...or you've got end play problems. Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 4, 2003 Share Posted June 4, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 4, 2003 Share Posted June 4, 2003 you should barely be able to move the crankshaft radially (other than to rotate it, of course). Certainly not a sixteenth of an inch--that's a couple of mm! Mike Quote Link to comment Share on other sites More sharing options...
