Guest Anonymous Posted June 3, 2003 Share Posted June 3, 2003 what exactly is detonation? is this what ppl refer to when they say pinging? am i right in thinking that this is combustion of the air/fuel mixture in the combustion chamber BEFORE the spark from the plug arrives? what exactly does it sound like/do? cheers knowledgeable ppls ozgeorge Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 3, 2003 Share Posted June 3, 2003 Pinging is uneven combustion in the cylinders and occurs after the plug fires. Combustion is occuring at other than TDC. It usually sounds like a light rattling when under load. Detonation is the same. Not sure if "detonation" is considered a misnomer or not. BTW pinging can occur on the piston upstroke and bust rods/rod caps. Run-on or "dieseling" is the motor running after you switch off the key. All of the above can be caused by advanced timing and/or low octane. There!My typing finger hurts! HTH! Ray Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 3, 2003 Share Posted June 3, 2003 URL: http://www.streetrodstuff.com/Articles/September_2000/Engine_Basics_II.php The link is a good description. Quote Link to comment Share on other sites More sharing options...
