Site update - fuel tank restoration and snorkel removal.
URL: http://www.instantop.com/cyclepages/kreem.htm
Don't mean to sound like a "Nervous Nelly", but JB
WELD!!! Man, we're talking your life here. The 02
fuel tank is already suspect and in more than one
occasion people have been seriously burned and
killed by rear end accidents. In these cases, the 02
tank will split in half and spew fuel all over the
trunk, then ignite. Since there is a poor seal
between the trunk and cabin the resultant
explosion of flame and fuel vapor can and will
enter the cabin.
You do really great work and have a beautiful son.
Think twice about that fuel tank.
Lastly, if you MUST use that tank, there is a product
called "Kreem" that you can use to line your fuel
tank. It basically makes a flexible bag inside your
tank. I used it in many vintage British motorcycle
fuel tanks with excellent results. It's popular
amongst the vintage bike crowd and is an
elastomer coating, so it resists cracking and
tearing on impact. I believe there are a few
products out there now so do a little search. Kreem
always worked for me and I have never tried any
other product, so as to how the others work, I
cannot vouch.
Please don't take offense. I'm not dismissing the
great work you did. It's just that I was seriously
burned over 30% of my body when I was a kid
(mostly 3rd degree burns... tons of surgery and
skin grafts!). It was a fuel tank related fire, so since
then I have taken every precaution when dealing
with fuel and fuel tanks.
Give Kreem a try or get a new tank.
Ethan
URL: http://www.2002tii-restoration.com
I always try to keep an open mind. Thank you for sharing your experience and your knowledge. I will look into Kreem.
As far as the JB weld goes, it was only used to rebuild the flange. I did not have to touch the original factory seam weld. Asuming that the seam weld is still sound, and I believe that it is, the tank is no more likely to split than when it was new.
Your points are well taken. Thanks.
Martin
'73tii
an acid to etch the rust out before application.
Good stuff.
Once again, great work Martin. Your 02 is gonna be
beautiful when your done.
Ethan
