Guest Anonymous Posted May 30, 2003 Share Posted May 30, 2003 My car ('73) has the standard antenna on the driver's side of the car (on the left A pillar) as well as an amplified Hirschman antenna on the roof - right on the very front of the roof in the center, (I believe this is the location of the antenna on an E30 M3). I would like to eliminate both antennas and add a glue on or stick on type antenna to the rear glass, as found on modern US-made cars. Does anyone know of a source for such an antenna? Does anyone know who can supply a replacement Hirschman mast? Thanks, Larry Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 30, 2003 Share Posted May 30, 2003 signal as a mast type antenna--they're more directional which will cause null spots when you're traveling in certain directions, especially with a weak station tuned in. Replacement Hirshmann masts should be available from the usual sources--Bavarian, Max etc... Cheers Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 30, 2003 Share Posted May 30, 2003 URL: http://www.probmw.com/ (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 30, 2003 Share Posted May 30, 2003 URL: http://www.hbci.com/~tskwiot/2002.html if your looking for other than OEM. I bought one of these for my daily driver audi CQ, it is tiny: http://www.antennaworld.com/eshop/Default.ASP?WCI=ItemDetails&WCE=AW-276E Tim Quote Link to comment Share on other sites More sharing options...
