Bad Steering Box? ...Opinions?
Yep, i'm fightin' the front-end wobblies.
With the center track rod linkage disconnected my steering box arm makes a slow heavy clunking sound when I push/pull up/down on it.....is some vertical play normal or is this something that can be adjusted?.. or.. gulp, is it toast?
Thanks in advance.
comet
'76 2002
Vertical play is NOT a good sign. Rotational play isn't much better(but can be adjusted out to some degree). remember, you're messin' with something that hasn't gotten much attention by any of the POs for the past 30 years. Maybe it's time for a rebuild.
