All of a sudden the turn signals stopped working??? Hazard
'74 Tii; I was driving along and they just quit, both left and right signals, hazard light blink no problem. Where do you start?
Of course not! It is always the most expensive part the fails! LOL
You can try to remove the switch, and clean it up with a good contact cleaner, you may be able to save it.
turn signal flasher unit clicking? Does the interior repeater light in the dash blink? If so, the flasher unit itself is OK. Try unplugging the multiprong connector on the back of the 4 way flasher switch and checking it for loose connections...if memory serves me, the power to the turn signals comes through that switch...check that before delving into the turn signal switch itself; if it's not getting power, the turn signals won't work.
Post what you find...
Mike
