Guest Anonymous Posted May 27, 2003 Share Posted May 27, 2003 I've just finished bringing a '76 2002 that had been sitting for 10 years back to life and have everything running nicely, except for a strange problem with the brake booster. With the booster connected to vaccum, the brakes won't fully release after they're pressed. You can easily pull the pedal out with your toe, but even after adding a second return spring to the peadal, it won't return all the way on its own, causing the brakes to remain partially on and drag. I rebuilt the pedal box, which had no effect, and then realized that the problem only existed with the car running and vaccum in the booster. In order to drive the car, I disconnected the booster and am just running manual brakes right now. My limited understanding of the brake booster leads me to believe that after the pedal is released, vaccum is not being re-established in the rear chamber of the booster, so equilibrium doesen't exist between the front and rear chamber. My question is, is there a way to fix this, or do I just need to replace the booster? Am I overlooking something simple? I'm fine driving it unassisted for now, but it will eventually be my brother's car and I'd like to have it working for him. Any ideas or suggestions would be appreciated, - Dave Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 27, 2003 Share Posted May 27, 2003 URL: http://www.zeebuck.com/02bc/index.htm (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 27, 2003 Share Posted May 27, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 27, 2003 Share Posted May 27, 2003 ordinary vacuum or heater hose will collapse...and you did lubricate the linkage between the M/C and the pedal--the part that's in the engine compartment. Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 27, 2003 Share Posted May 27, 2003 ... and the hose and check valve are from a known-good 320i that I stripped for parts after I got rear-ended. I think the problem is within the booster, so I'm probably just going to replace it, but I thought maybe there's some way to fix it, since it works as far as assisting the brakes; it just won't release all the way. Thanks, Dave Quote Link to comment Share on other sites More sharing options...
