I have developed an irritating squeaking noise from the front end that happens on bumps and more frequently under braking. Ideas? The rubber up front is probably original so poly bushings all around probably will be the fix?
1976 BMW 2002 Fjord Blue • Ireland Stage II • Bilstein Sports • Ireland Headers • Dual Weber DCOE 40s • 292 Cam • 9.5:1 Pistons • 123Tune Bluetooth • 15" BBS
2018 BMW M550i X-Drive
1964 Volvo Amazon Wagon
http://www.project2002.com
probably
try soaking all the front end bushings with WD-40 and see
if all is quiet ?
but then again - any squeak from your 30+ year old car might be a
signal that something mechanical is about to FAIL AND KILL sombody.
better take a LOOK
'64 R27 250cc #383851 18,000m
Remember that poly bushings will make your ride much rougher/harsher. I'm suprised c.d. didn't mention it, but good old OE rubber bushings would probably give you another 30 yrs. of pleasurable driving. Might want to check your motor mounts and tranny mount while you're at it. The engine/tranny could be shifting forward under braking if either of those need replacing.
Bob Napier
Bob Napier
so true Rubber is where its at for a street car. But of course thats only 1 opinion
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
It may seem silly, but also check/lubricate the throttle linkage pivot point high up on the firewall.
69 1600 Voll Cabriolet (The Cab, aka Cabriolina)
69 (1600) Lotus Elan (the Lo-lo, aka FunElan)
16 (2500) Nissan Rogue (hate that CVT)
Thx guys...I'll go for rubber!
