When I'm speeding down the highway in my '74 2002, gas pedal pressed, all's fine. When I let up off the gas pedal, still cruising along, I can see white smoke pouring out of my tail pipe. Is this normal or is there something wrong here? I have to add oil periodically as it drops a little low.
2002 to 2112! What a Rush!-- '74 2002 - '91 Saab 900
Light gray smoke on de-cel may mean bad valve seals. The knowledgeable can tell you about the motor sitting at an angle, vacuum and all those technical things I know nothing of.
1972 2000tii Touring #3422489
FAQ member #5
Are you sure it's white and not blueish? Also what weight oil do you use? I used 10w40 for a while and could blow a HUGE cloud out of the back of my car on decel. You should be using 20w50, it helps a lot. And even with new valve seals and 20w50 on decel you will smoke a little. But the general code for smoke is;
White= Coolant
Grey/Black= Fuel (too rich)
Blue= Oil
Hope this helps!
-Nathan
