Hello, I got this diff when I bought my 73 and I am wondering what sort of ratio it is. I've searched but can't find any info. Thsee are the numbers I can locate on it.
33.1 1204 818 3.2 225 on the cover
And on the diff 1201 5260 Gts 35
Thanks in advance.
1971- 02-Malaga -(Ginger)- 2nd owner
1973-02- chamonix (sold)
pardon any grammatical errors in my posts, im probably on my cell phone.
those are all 'casting' numbers - useless
remove the screws and rear cover and look at the ratio numbers stamped into the larger ring gear - at the same time look for any bearing material or nastyness with the ring/pinion/spyder gears - which
you should do anyway before you install this diff in any car.
Flush it out and reseal the cover - paper gasket required
'64 R27 250cc #383851 18,000m
  • 1 year later...
-or maybe you can still see it stamped into the driver side of the diff.
40 / 11= 3.636
And if there were an S in between the numbers, it would be an LSD.
My diff has the exact same 3 markings as the diff pictured above; is the "5" looking digit the "s" that denotes LSD?
Das Moneypit, an F20-swapped 1973
um... try jacking up the rear of the car and counting the number of turns of half shaft to drive shaft. or use the RPM chart in the FAQ section and get a rough gauge based on the rpm charts for different differentials. or take the diff off and crack it open. all depends on how neurotic you want to get with it.
Pic of LSD. S for slip in between R&P designation, also white S painted on pass. side of diff.
Jason I thought you had one made of Gold ?
40 / 11= 3.636
I think the other two numbers (middle and bottom) designate the month and year of assembly. Possibly September (9) of 1974 (4). Not 100% sure without looking in the blue book again to confirm.
