Guest Anonymous Posted May 26, 2003 Share Posted May 26, 2003 Going to replace the master cylinder, which I have, but I don't have the tubes and plastic plugs that go into the top. If I can get the PN, then I'm going to check with the local BMW dealer for a price, if not then I'll order from somebody. OR... Are the parts from something more readily available, perhaps at a local car shop? Lets hope the smoke is brake fluid getting sucked through the booster hose. All other fluids are good (so far), and the brake fluid is dropping, and not accumulating on the garrage floor, or in the pedal box. Lets hope!! Thanks, Jonathan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 26, 2003 Share Posted May 26, 2003 The part number for the plug (seals) is: 34 31 1 103 205 The part number for the connector is: 34 32 1 102 282 Quote Link to comment Share on other sites More sharing options...
