Earlier this week I embarked on a project to tune my 02 up for the winter months. I can only drive my 02 (no A/C) in the fall/winter/spring months here in Phoenix. So I chased the plug holes, replaced the plugs, reset the timing, and was preparing to go out for a short drive before I dialed in the carb...
I was in the garage looking under the hood and playing with my 32/36. I have it a little gas, and there was a really loud metal on metal 'POP' then she died. It turns out that the first cylinder 'rejected' the spark plug and flung it onto the floor of the garage...
Because the engine was warm I gingerly tried putting the plug back in but it never would tighten up in the hole. I was able to use my fingers to wiggle the plug out of the hole. I am going to wait until it cools down and really get in there to see what's going on, but I think the hole is really buggered up! I just can't win.
Look forward to more questions from me about removing/reinstalling the head in the near future.
Peace,
Brian
72 inka
I'm guessing a Heli-coil is in your future.
Sounds like the plug thread is stripped and the compression spit the plug out.
I think it can be fixed without taking the head off if you find the right shop.
71, flat black
Beat to fit, paint to match.
Do what you love and you'll never work a day in your life.
"Some people spend a lifetime wondering if they made a difference, Marines don't have that problem" - Ronald Reagan
I love the title of this thread! Heck, I'm 60 and I plan on working on my car tomorrow so rest assured, I will screw up as well, I've got plenty of experience screwing up!
heli coil sounds like the answer and it's not too tough a fix
good luck
Jeff
A tip for the helicoil insertion. The hard part is getting the junk out of the cylinder.
Put the cylinder at top of travel.
Insert rag soaked in oil to catch the shavings.
Tape a straw to your shop vac to suck out the shavings. Then pull the rag and suck it again.
Spin the engine with the plug out to eject the last few shavings.
BMW Lotus Healey Miata x 2
If you decide you want a shop to fix it, try Beyer Motor Works in Chandler. This is a very modern shop, but the owner, Roy, has been daily driving his 1971 2002 since the day he bought it new at the dealership he was working in at the time. It's at his shop every day he is there. They are not cheap, but they've done work on both my '75 and my wife's '76 and the work has been very good.
Beyer Motor Works
300 S. 79th St
Chandler
480/961-9449
if you replaced your plugs, you may have a helicoil that came out w/ the old plug.
Yea I'd look in the trash at your old plugs.
John
1665778
Obviously it's late (at least on the east coast...), but if I were in this situation I would be thinking about calling a Priest; just to inject a bit of levity...
Tip from a clumsy oaf. I used TimeSert instead of Helicoil. Worked great. Slather the tap with Vaseline to catch any metal shavings and turn it slowly
when cutting new threads.
So do you guys recommend trying the helicoil with the head on? I assume I should remove the exhaust manifold to give me room to work.
Also, I did some poking around this am. The spark plug shot out of the cylinder, bounced off the stock manifold cover, and right into the washer bottle breaking it. Good times!
From what I have heard, TimeSert is considered to be a better repair compared to HeliCoil. I would call your local machine shop, and see which method they prefer. I have never used a TimeSert kit before, but I do believe it is much easier to center, as compared to a Helicoil.
1971 BMW 2002
38/38 DGAS
292 cam
TEP 4-1 header
Ansa Sport muffler
Bilstein Sports
H/R Sports
Full Urethane
Bavaria Control Arms/02 Tension Rods
IE adjustable sways
15x7 König Rewind
Time-Sert is the best repair
remove the other 3 plugs and inspect those holes also.
if they look buggered up, loose, missing threads,
then your either towing it to a shop with experience
to work with the head inplace, or the other alternative
is removal of the head - to also inspect it for other
issues like valve/seat condition, warpage, cracking,
generally testing, inspecting, and repairing the head so
you can have 20+ years of carefree driving.
http://www.amazon.com/BIG-SERT-Oversize-Spark-Thread-Repair/dp/B003RLGT18
'64 R27 250cc #383851 18,000m
Helicoil install tip. Rotate the engine so the intake valve is open and run a steady stream of compressed air into the cylinder, and thus out the spark plug hole. This will help push chips out and not let them get into the cylinder.
Cheers,
Carl
