Hello Group:
We see that the 2002 has a number of “ball-and-socket” joints in its steering linkage and suspensión:
Inner tie rod ends
Outer tie rod ends
Center tie rod or “drag link”, and the
Ball joints mounted on the control arm
In your collective wisdom/experience, which of these tend to exhibit the greatest wear and are most frequently changed? Similarly, which appear to be “indestructible”, if any, and hardly ever wear out or last a long. long time?
Also, the rubber mountings up front….the inner and outer control arm bushings and the front rubber mounting for the tension strut: Which of those seem to wear out any faster than the others?
Thanks in advance for your answers and input.
Saludos,
Brian McCall
El Salvador
2004 320i (E46)
1985 318 (E30)
1965 Citroën 2CV
people here who finally replace All of the above
cannot believe the improvement and wish they
had done it first before other 'improvements'
that said
the lower ball joints are probably the longest lived
and only get replaced when you remove the front
strut housings for shock replacement
all the other parts are needed after 30 years
and generally removing one includes disconnecting
neighboring parts - so they are all done at one time
all are available from many sources including
any BMW dealer - prices are very reasonable
cheep actually
include to your list idler arm bushings
motor mounts - and inspection of the front subframe
mounting arm for the left motor mount which cracks
welcome aboard
'64 R27 250cc #383851 18,000m
Many people will also change all of the old, worn out suspension rubber parts with polyurethane. Doing so will make the car feel much more firm, but maybe too much.
A well sorted 2002 with all fresh rubber bits feels great on the road. Be sure of what you want your end product to be. If you are building a race car just for the track that is one thing. A car that will be driven on real, and sometimes rough, roads may not need all those race parts.
The upper strut bearings are usually overlooked. The upper part of the rubber should be concave and have no cracks. Many 02 owners have neglected these and had to repaint their hoods when the strut poked up and dented it.
Steve J
& too many bikes
Only the drag link joint (in my experience) seems to have
a finite life-
everything else lasts almost forever.
As in, it's not uncommon today to still find original
everything in a 2002's front end.
Except for the center link.
Tie rods go forever (until the rubber rots)
Lower ball joints go a long time.
The rubber bushings do eventually wear out.
a finite life-
Forever must be a bit less than 250K miles, because that's when I drilled out the rivets and replaced my dry, naked, ball joints. And rod ends. And drag link. Now I only need one finger on the wheel . . .
1973 tii, agave, since 1992
1973 tii block 2763759
1967 Mustang GT fastback, since 1986
1999 Toyota 4Runner, 5 speed, ELocker, Supercharged
