FREE - Local Pick-up Only:Stock Resonator+Muffler+Driveshaft
All are used.
Located in 11363 (Queens, NY)
Local Pick-Up Only - weekends or thurs and friday evening.
As you can see, to take the exhaust out, I had to cut a part of it out but can re-weld it for you or you can just couple it after you install it on your car.
The muffler was rusted or otherwise repaired by the PO but sounded and 'performed' as a stock muffler would. The resonator pipe also has some welds on it, from PO.
FYI - muffler comes out to passenger side, not in the middle.
The driveshaft was also used, but as you can see, its support has been broken off and needs to be replaced.
Feel free to ask any and all questions.
Reason why I offer local pick-up is so you can determine if this is for you or not. Thanks all.
