Guest Anonymous Posted May 25, 2003 Share Posted May 25, 2003 ok i found a pretty sweet 5spd tranny at a wrecking yard today, put i didnt pull it because i was curious to know if...i can use the driveline out of the 320 or if i still have to have it shortened and balanced. it was the 4 hole flange so i just need to know if i should take that too. thanks! mike golf 72' Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 25, 2003 Share Posted May 25, 2003 and shorten the front half part. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 27, 2003 Share Posted May 27, 2003 the front of the 320 driveshaft to get the three bolt driveshaft flange. You can then shorten the 320 front section, or shorten the 02 front section and weld the 320 flange onto it. Either way, be sure and re-balance the driveshaft. Mike Quote Link to comment Share on other sites More sharing options...
