DREMEL cutting wheel gently on the inside of the fender
slice the end of the rivet off so the backup washer
comes off
drilling might get sloppy and enlarge something
'64 R27 250cc #383851 18,000m
If you are allowed access.
If not, get the right tool for the job.
They have short drill bits made just for removing blind rivets.
Steve J
& too many bikes
Use a thin center punch to push the "nail"(the "pop" part of the rivet) through first. Then drill out the softer rivet part.
Trying to drill them with the "nail" part still in the center makes the drill want to wander all over.
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
I think I too would drill em. Just do enough got the head to come off and the gently remove the flare. Or are you going to try to replace them with fasteners one at a time?
John
1665778
the rivet so if the drill does skitter, it won't hurt the paint. And start your drill slowly (presuming a variable speed drill) until the bit is established in the hole it's creating.
This also works when you're drilling holes to mount an outside mirror...
cheers
^^this^^
