i have a early 73 tii with the CR 235/5 getrag box in it,i was out driving last weekend and when i was going around the hills(foot flat of course) i noticed a pop noise while changing gear(no crunching of gears)didnt think much of it till i stopped and had it idling out of gear and had alot of vibration noise coming from the box(started to worry a bit) which got worse when i reved it,but noise went away when clutch is in.to me it sounds like a clutch release bearing is shot but i want a second opinion on the matter.it also shudders during take off in 1st and reverse.
any ideas would be appreciated
julian
73' 2002tii roundie cr 5spd 2751420
yer clutch is toast
your gearbox needs to come out so u can see
what's blown up
'64 R27 250cc #383851 18,000m
I don't think it's the clutch...
...I'd check the gearbox, especially the countershaft bearings,
before driving it more. The C/R boxes aren't cheap to fix.
But new bearings aren't hard.
Gordon?
cheers boys for the info,like usual you gotta pull things out to know what actully blew up! as i was tryna avoid.
Oh, nuts, before you pull anything see if maybe you had a
mount come loose, and your exhaust is hitting the body somewhere.
Just in case...
ok il have a look,i was under there last week because my shifter plate came loose and didnt see the mount in any trouble but it is a ireland urethane yellow and noticed there yellow engine mounts have been braking(posts by fellow faq'ers)
cheers
