Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 Want to put a 3 1/4" radius bend in 1" tubeing, just past 90 degrees. Understand that there may be a low temp. metal the tube can be filled with, to prevent distortion. Trying to find out what it is, if not we'll give sand bending a try. Thanks....... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 It melts around 160 so you can melt it with hot water. After you use it you can melt it out into a tub and save it to use again. Some metal shops may have it also under different names, but it is usually just a mixture of bismuth metal and some other types. HTH, B Quote Link to comment Share on other sites More sharing options...
