Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 If I needed to wire something that I only want to be "on" while the engine is running, how would I go about doing this? Not when they key is on but while the engine is actually running. Thanks, -jaycen 72 tundra tii 72 agave 2002 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 If not I can email you the directiond on how to wire it in. Andy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 there is no circuit in the 02 that "knows" when the motor is running. For example, when the key is in the "on" or "run" position, the motor can be running or not. What are you trying to accomplish? Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 URL: http://www.holley.com/HiOctn/ProdLine/Products/IS/ISA/870-100.html Holley sells an oil-pressure-operated switch, Part #: 870-100, that switches "on" at 10 psi. It has a 1/8 NPT thread, might fit the adapter VDO sells for its oil pressure gauge sender. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 Put a relay on the oil pressure sender. When the light goes out, the circuit can turn on. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 warning light has this same potential. Hmmm.... Quote Link to comment Share on other sites More sharing options...
