Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 If a dizzy falls in a 2002 and no one is around to hear it, does it make a sound? My '72 motor makes a bit of a high-frequency squeaking that almost sounds like a belt but seems to be coming from the distributor. It also is regularly making gray dust inside the cap (seems like my last '02 didn't do that). Any thoughts guys? Thanks to all for a great time down in Palo Alto! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 apply some grease to pertinant areas and if it still does it. . .. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 URL: http://www.zeebuck.com/02bc/index.htm Yep, they can run dry, and start squeeling. Pull the rotor out, and drop a bit of oil on the felt pad. It might be too late for yours, but it's worth a try. Al Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 I don't know where your noise may be coming from but I do know this: a worn distributor shaft will allow the rotor to move enough to cut into the contacts on the distributor cap. This creates fine copper dust. In my case, the dust would get so bad that the optical pickup on my crane ignition would sometimes stop working (too little light passing through the heavy film of dust.) For a long time I replaced the cap and rotor more frequently than others might. This was an attempt to avoid the cost of a new dizzy-- the cost of cap and rotor replacement over time will (as you may find) become justification enough. I can't say that this IS in fact your car's problem but that is what it "sounds" like to me Good luck Bill Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 I'm thinking the problem must be farther down... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 23, 2003 Share Posted May 23, 2003 dry at the rubbing block on the points and make a loud enough "squeal" to hear from inside the car over the engine & exhaust noise. Quote Link to comment Share on other sites More sharing options...
