Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 The rubber drive disk between the tranny and the propshaft broke for the second time in 6 months. After removing what was left of it, I noticed the gap between the two flanges is wider at the top then on the lower half. Could that be the problem? And how do you correct that; it looks like I can only align the propshaft sideways by the middle bearing. Thanks, Hugo Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 22, 2003 Share Posted May 22, 2003 check your motor mounts and see if they are worn causing your motor to tilt down a little in front and your trans to tilt up a little in the back. If your trans mount cross brace (don't know the real name) is bent up it'd do the same. When you put a new one on, use some type of thread locker on the nuts. hope it helps and best of luck, Britt Quote Link to comment Share on other sites More sharing options...
