Guest Anonymous Posted May 21, 2003 Share Posted May 21, 2003 I installed a 320i cooling fan. but after monday heat the fan gave out and i noticed the relay is warm and the fuse (european type 30 amp) has melted. Now the fan dont work but the fuse was replaced and the relay. The wiring is fine used a Bosch relay. Do you guys use the white ceramic that most 325 and 320 wired with the stock cooling fan? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 21, 2003 Share Posted May 21, 2003 if it doesn't spin it is dead! steve Quote Link to comment Share on other sites More sharing options...
